[quote name='Slayer2k4' timestamp='1440641525' post='3355165']
http://engineering.mit.edu/ask/can-compu...dom-number
One thing that traditional computer systems aren’t good at is coin flipping,” says Steve Ward, Professor of Computer Science and Engineering at MIT’s Computer Science and Artificial Intelligence Laboratory. “They’re deterministic, which means that if you ask the same question you’ll get the same answer every time. In fact, such machines are specifically and carefully programmed toeliminate randomness in results. They do this by following rules and relying on algorithms when they compute.”
You can program a machine to generate what can be called “random” numbers, but the machine is always at the mercy of its programming. “On a completely deterministic machine you can’t generate anything you could really call a random sequence of numbers,” says Ward, “because the machine is following the same algorithm to generate them. Typically, that means it starts with a common ‘seed’ number and then follows a pattern.” The results may be sufficiently complex to make the pattern difficult to identify, but because it is ruled by a carefully defined and consistently repeated algorithm, the numbers it produces are not truly random. “They are what we call ‘pseudo-random’ numbers,” Ward says.
Isso é filosofia e não matemática...
No fim, eles são números aleatórios, só pecam na sua essência...
[quote name='mrdarc' timestamp='1440708863' post='3355379']
Eu devo ser muito azarado então, porque nunca ganhei uma lendária em pack comprado com dinheiro.. Em compensação já tirei +25 em packs comprados com gold.
Shhhhh
não fala alto
ninguém aqui leva em conta os fatores do lado do jogador
o negócio é elaborar teorias de como a blizzard consegue manipular nossas mentes e nos obrigar a ser escravos desse jogo
