06-13-2014, 10:05 AM
(Esta mensagem foi modificada pela última vez a: 06-20-2014, 09:25 AM por vempire_ghost.)
Saiu no Diablo Tetinhas um resumo de uma conversa que tiveram com um dos devs sobre o que virá no mítico patch 2.1, algum dia, se não for cancelado como o 1.1 foi.
Agora esperar sair o bendito PTR pra ver na pratica como as coisas vão rolar, espero que o revamp dos lendários antigos (mais um revamp, isso tá virando moda) não afete só a ladder, e que não cortem metade do que pretendem por durante o curso do PTR.
EDIT: Prévia do patch https://us.battle.net/d3/en/blog/1424455...17-06-2014
Citar:Old Legendaries are going to get revamped in 2.1, but not retroactively, so hoarding them now is pointless
No ETA for 2.1 yet, but some information about the patch will be shared 'pretty soon'
Details about Legendary Gems are coming 'very soon' in a blog post
The aforementioned Legendary gems will most probably fit into Rings and Amulets
The devs are currently looking at how the Infernal Machine events can be improved (both as process and reward structure)
The so-called "Hellfire Amulet" will come with 2.1
Hellfire Amulet will unlock a randomly rolled Passive for your class
Tiered Rifts are not going to be static dungeons: they are random - same as Nephalem Rifts, but the devs are working on toning down the amount of randomness that can impact the time for finishing a Rift
Reduction of Conduit Pylon's power is being tested internally for Tiered Rifts, because the devs don't want players at the top of the Leaderboards to be there just because of luck
The monsters in Tiered Rifts will drop no loot, but the bosses at the end will compensate with huge amounts of loot, including a very high chance for Legendaries, gems, crafting plans, and so on
Cindercoat used to be even stronger internally and already was tuned down, but Blizzard is aware that it is still REALLY strong; no plans to nerf it though
Invoker Set was originally intended to be a Crusader set as Thorns was a larger theme for Crusaders
The devs are working on a new Crusader set that will buff Phalanx or Shield Bash
Kadala is supposed to have a more positive attitude, but there's a bug that causes her to only speak the lines associated with getting Blue items, while she would be much nicer if you get a Legendary item: she should say stuff like "Have fun with your paperweight" when you get a Blue item while she should congratulate you on getting a Legendary
Travis Day Quadboxes Crusaders, sometimes while watching TV and playing Hearthstone at the same time
The Theorycraft Thursday tends to not feature the current high Torment builds because they're already well known
New Theorycraft Thursday streams will be conducted every 6 weeks or so
' /> e na mudança do heal, espero que buffem o LoH do paragon, não tenho nenhum item com LoH e não teria interesse de trocar algum stats por ele sinceramente.
![[Imagem: lKNmE.jpg]](http://i.imgur.com/lKNmE.jpg)
